[GRASS-user] Reprojection command
Giacomo Piva piva at meeo.it
Thu Aug 5 03:40:02 EDT 2010
Hi all,
Which is the command to use for reproject an image?
I usually use gdalwarp to reproject the image BEFORE grass command, but
now I want to reproject an image between two grass command.
Thank you
Giacomo Piva
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
