[GRASS-user] Reprojection command
Hamish hamish_b at yahoo.com
Thu Aug 5 04:34:29 EDT 2010
Giacomo wrote:
> Which is the command to use for reproject an image?
> I usually use gdalwarp to reproject the image BEFORE grass
> command, but now I want to reproject an image between two
> grass command.
r.proj. You pull a map in from another mapset into the current
computational region (see the help page).
Hamish
