[GRASS-user] addons installation under GRASS 7.0-svn
Markus Neteler neteler at osgeo.org
Mon Aug 16 06:17:33 EDT 2010
On Sun, Aug 15, 2010 at 6:48 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Nikos Alexandris wrote:
>> > perhaps not absolutely all, but between the C lib changes
>> > and the (I hope hope temporary) removal of shell script
>> > support, it is safe to say that most will need some
>> > porting work.
>> Oh... :-O. Shell script(ing) ability completly removed in grass7x?
> You can still run GRASS commands from shell scripts, and you can still
> use g.parser in shell scripts.
I have tried but get
GRASS 7.0.svn (nc_spm_08): > sh i.fusion.his
sh: i.fusion.his: command not found
  File "/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/gui_modules/menuform.py",
line 2219, in <module>
    task = grassTask(cmd[0])
line 371, in __init__
    processTask(tree = etree.fromstring(getInterfaceDescription(grassModule)),
line 1994, in getInterfaceDescription
    raise IOError, _("Unable to fetch interface description for
command '%s'.") % cmd
IOError: Unable to fetch interface description for command 'i.fusion.his'.
Markus
