[GRASS-user] addons installation under GRASS 7.0-svn
Mon Aug 16 17:59:22 EDT 2010
Markus Neteler wrote:
> >> > perhaps not absolutely all, but between the C lib changes
> >> > and the (I hope hope temporary) removal of shell script
> >> > support, it is safe to say that most will need some
> >> > porting work.
> >> Oh... :-O. Shell script(ing) ability completly removed in grass7x?
> > You can still run GRASS commands from shell scripts, and you can still
> > use g.parser in shell scripts.
> I have tried but get
> GRASS 7.0.svn (nc_spm_08): > sh i.fusion.his
> sh: i.fusion.his: command not found
Does it have the execute bit set? If it doesn't, g.parser can't
execute it. That has always been the case; it isn't specific to 7.0.
