[GRASS-user] addons installation under GRASS 7.0-svn
Markus Neteler neteler at osgeo.org
Mon Aug 16 18:55:10 EDT 2010
On Mon, Aug 16, 2010 at 11:59 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> > perhaps not absolutely all, but between the C lib changes
>> >> > and the (I hope hope temporary) removal of shell script
>> >> > support, it is safe to say that most will need some
>> >> > porting work.
>> >> Oh... :-O. Shell script(ing) ability completly removed in grass7x?
>> > You can still run GRASS commands from shell scripts, and you can still
>> > use g.parser in shell scripts.
>> I have tried but get
>> GRASS 7.0.svn (nc_spm_08): > sh i.fusion.his
>> sh: i.fusion.his: command not found
> Does it have the execute bit set?
Yes.
> If it doesn't, g.parser can't
> execute it. That has always been the case; it isn't specific to 7.0.
ls -la i.fusion.his
-rwxr-xr-x 1 neteler neteler 3867 2009-09-29 21:36 i.fusion.his*
The problem was that it wasn't in the search path.
Sorry for the noise (maybe there is a way to catch this?).
Markus
