[GRASS-user] Re: Table is not created with vector map
Maris Nartiss maris.gis at gmail.com
Fri Aug 20 16:44:15 EDT 2010
Bad news for You - that vector file is corrupted. If You just imported
it - it failed to import correctly. If You run some other module - it
corrupted that file (and it's a bug). Also it lacks attribute table.
Also - when You ask for help, don't forget to include such details as
GRASS version, OS, LFS/64bit-ness and GRASS source (SVN or
distribution packages).
Good luck finding corruption source,
Maris.
