[GRASS-user] Re: Table is not created with vector map
Micha Silver micha at arava.co.il
Sat Aug 21 12:45:56 EDT 2010
On 08/18/2010 01:39 PM, LeeDaniel wrote:
> Alright, I've run the same test again with the same raster after having
> deleted my mapset and importing it again into another location. I've read a
> lot in the forums about coor files being too large and it seems that my
> hypothesis of the vector being too large is completely invalid. Here some
> additional info:
> When I use v.build I get the same error:
> Coor files of vector map<homogeneous_areas at PERMANENT>  is larger than it
> should be (94546466 bytes excess)
> Nonetheless, v.build runs to the end.
> Trying to add a column after running v.build gives me the same problem. I
> get the following message:
> DBMI-DBF driver error:
Hi Daniel:
I've lost the train of your specific problem, so this suggestion might
be "off the wall" but you might try switching to an sqlite database
rather than dbf files. Sqlite, I believe, handles large tables better,
and it has a richer set of SQL compatible query options, etc.
That's done with the db.connect command
> Table 'homogeneous_areas' doesn't exist.
> Error in db_execute_immediate()
> ERROR: Error while executing: 'ALTER TABLE homogeneous_areas ADD COLUMN area
> double precision
> ERROR: Cannot continue (problem adding column).
> Still no further.
> Running v.digit also doesn't help; I have the same problem. I also tried
> exporting the vector as a shapefile and that didn't work either; GRASS
> complained about not being able to access the level 2 topology data.
> Any help would be appreciated, or at least a nudge in the right direction.
> I've read a lot of stuff online but haven't found anything that helps me in
> this situation yet and am confident that GRASS can do this... The coor file
> is only 90 MiB large with a topo file of 231.8 MiB, therefore not huge
> files. Of course, I wouldn't mind doing it with r.area, but my thread there
> has also died off... People, I'm sorry if I'm asking stupid questions but at
> least I'm trying! :P
> Thanks a bunch,
> Daniel
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
