[GRASS-user] Displaying layers - GRASS 6.4.0RC7 with MSYS
Chethan S chethanuniversal at gmail.com
Sun Aug 29 07:53:27 EDT 2010
Hello!
I natively use GRASS in ubuntu but wanted to try it in windows as well. I
use GRASS 6.4.0RC7 with MSYS and referring to Open Source GIS -  A GRASS
Approach I wanted to display layers using following commands for the sample
North Carolina dataset -
g.region rast=elevation -p
d.erase
d.rast elevation
d.his h=elevation i=elevation_shade and so on...
Prior to all these there was d.mon x0 command. It resulted in an error. It
was also mentioned that X server system does not work in windows and I can
use gis.m. I want it to display in wxGUI. The commands I typed in gave no
results. The map display of wxGUI interface gives no output unless I key in
the commands one after another in GRASS Layer Manager under "Cmd>". Its a
difficult process as I have to erase the previous command before entering
next one.
Is there any other way to get dynamic outputs from MSYS shell interface or
is using GUI the only way. I am not interested in using the windows command
interface or text interface to grass.
Regards,
Chethan S.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100829/abb8774b/attachment.html
