[GRASS-user] Running Grass Remotely
M S mseibel at gmail.com
Mon Jan 11 11:22:27 EST 2010
If you would like to grab the session on your monitor display, there
is the x11vnc package which will get that session.
Alternatively to getting the session active on the monitor, is using
virtual sessions.  I have used vnc4sever, but with the newer versions
of KDE and desktop, it had a lot of artifacts and hard to read the
display.  I moved over to NX Machine, http://www.nomachine.com/.
There is also an open source equivalent FreeNX
(http://freenx.berlios.de/) in Ubuntu repositories.  The one by
nomachine allows max of two connections I believe, where the freeNX
does not have that limitation.
hope that helps.
Mark
On Mon, Jan 11, 2010 at 11:16 AM, stephen sefick <ssefick at gmail.com> wrote:
> I would like to run grass remotely on a server running ubuntu.  I
> would like to be able to forward the X11 to my desktop running ubuntu
> 9.10 over the network.  Any help or pointers to reading material would
> be greatly appreciated.
> thanks,
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods.  We are mammals, and have not exhausted the
> annoying little problems of being mammals.
>        -K. Mullis
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
