[GRASS-user] Running Grass Remotely
Markus Neteler neteler at osgeo.org
Mon Jan 11 17:29:54 EST 2010
Stephen,
you can easily tunnel X11 over ssh, just add -X. I am doing that
routinely (note the capital X).
ssh -X myserver
Then run GRASS as usual on the remote machine and all monitors,
windows will come over locally.
When using VNC, I prefer to install
http://www.karlrunge.com/x11vnc/
which is WAY faster than common VNC. My startscript for the server contains:
xhost +localhost
x11vnc -sloppy_keys -shared -remap DEAD -forever -loop2000 -bg -auth
/var/run/xauth/A* -ncache 10 -display :0
xhost -localhost
Then I use the related VNC client provided by Karl Runge on the client
server. Works great even over very slow connections.
Hope this helps,
Markus
