[GRASS-user] Arc Binary coverages- arggg!
stephen sefick ssefick at gmail.com
Wed Jul 14 09:20:33 EDT 2010
I don't have an info directory.  I tried using v.in.ogr to no avail.
So, I downloaded the nation hydrography dataset and now I am trying to
find out projection information.
thanks,
STephen
On Tue, Jul 13, 2010 at 8:10 AM, Mark Seibel <mseibel at gmail.com> wrote:
> Much to my delight, v.in.ogr reads the binary arc coverages.  I copied
> over the directory (which is the coverage name) and the info directory
> to a place on the Linux machine which has GRASS installed.  (not sure
> if the 'info' directory is needed, but it did preserve attributes).
> For the OGR datasource name, I pointed it to the "arc.adf" file, and
> it imported the coverage as a GRASS vector with points, lines and
> polygon features.  Attributes also preserved.
> Please let me know if you have any issues with this.  First time I
> tried this, and great to know it can read the binary coverages.
> Mark
> On Mon, Jul 12, 2010 at 8:02 PM, Mark Seibel <mseibel at gmail.com> wrote:
>> That's what I figured.  Then I am fairly sure this is what you're
>> after, http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ogr.html.
>>  Arc Vector coverages are stored in 2 directories.  One for geometry
>> (the directory is the name of the coverage) and the database is
>> contained in an 'info' directory.  The examples below are not clear to
>> me how it addresses this, but it does state it will do it.  I could
>> try some testing tomorrow if not figured out by then.
>> # Arc Coverage
>> We import the Arcs and Label points, the module takes care to build areas:
>> v.in.ogr dsn=gemeinden layer=LAB,ARC type=centroid,boundary output=mymap
>> # E00 file (see also v.in.e00)
>> First we have to convert the E00 file to an Arc Coverage with
>> 'avcimport' (AVCE00 tools, use e00conv first in case that avcimport
>> fails):
>> avcimport e00file coverage
>> v.in.ogr dsn=coverage layer=LAB,ARC type=centroid,boundary output=mymap
>> All the best.
>> Mark
>> On Mon, Jul 12, 2010 at 7:47 PM, stephen sefick <ssefick at gmail.com> wrote:
>>> Vector Coverages.
>>> On Mon, Jul 12, 2010 at 6:41 PM, Mark Seibel <mseibel at gmail.com> wrote:
>>>> Are these vector coverages or raster datasets?
>>>> Mark
>>>> On Jul 12, 2010, at 6:08 PM, stephen sefick <ssefick at gmail.com> wrote:
>>>>> I have a couple of files that are in this format...
>>>>> aat.adf  arx.adf     dbltic.adf  metadata.xml  prj.adf  txx.adf
>>>>> arc.adf  dblbnd.adf  log         par.adf       txt.adf
>>>>> they are arc binary data correct.  Is there anyway I can use these
>>>>> with GRASS or QGIS?
>>>>> Stephen Sefick
>>>>> ____________________________________
>>>>> | Auburn University                                   |
>>>>> | Department of Biological Sciences           |
>>>>> | 331 Funchess Hall                                  |
>>>>> | Auburn, Alabama                                   |
>>>>> | 36849                                                    |
>>>>> |___________________________________|
>>>>> | sas0025 at auburn.edu                             |
>>>>> | http://www.auburn.edu/~sas0025             |
>>>>> Let's not spend our time and resources thinking about things that are
>>>>> so little or so large that all they really do for us is puff us up and
>>>>> make us feel like gods.  We are mammals, and have not exhausted the
>>>>> annoying little problems of being mammals.
>>>>>                                -K. Mullis
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Stephen Sefick
>>> | Auburn University                                   |
>>> | 331 Funchess Hall                                  |
>>> | Auburn, Alabama                                   |
>>> | 36849                                                    |
>>>                                 -K. Mullis
Stephen Sefick
| Auburn University                                   |
| 331 Funchess Hall                                  |
| Auburn, Alabama                                   |
| 36849                                                    |
                                -K. Mullis
