[GRASS-user] problem with v.rast.stats
Helmut Kudrnovsky hellik at web.de
Sun Jul 18 06:42:42 EDT 2010
>Yvan wrote:
>> I'm using the last version of GRASS 6.4ORC6 for Windows. I
> >have a problem when I'm using the v.rast.stats function.
> >There is an error message about the script :
> >v.rast.stats -c vector=cadastre at mercier
> >raster=mntyzeron_5m at mercier colprefix=mnt
> >C:/GRASS-64-SVN/scripts/v.rast.stats: line 267:
> >v.db.addcol:
> >command not found
> >ERROR: Cannot continue (problem adding columns).
> >Restoring previous MASK...
> >(Tue Jul 13 11:14:49 2010) Command finished (8 sec)
> >Do you have any hint to solve this problem?
>Hamish wrote:
>Hello,
>can you test with one of the nightly builds of 6.4.0 and see if you
>still have the same problem?
>what if you remove the @mapset parts of the map names?
tested with the latest nightly WinGrass64-build:
v.rast.stats vector=myfire at user1 raster=elevation at PERMANENT colprefix=te
v.rast.stats works normally.
Helmut
___________________________________________________________
Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20100718/b780b648/smime.bin
