[GRASS-user] Re: problem with v.rast.stats
Hamish hamish_b at yahoo.com
Sun Jul 18 08:14:40 EDT 2010
Helmut:
> tested with the latest nightly WinGrass64-build:
> v.rast.stats vector=myfire at user1 raster=elevation at PERMANENT colprefix=te
> v.rast.stats works normally.
I just tried with 6.4 nightly build r42815 on XP + the example in
the man page+dbf, and it seemed to freeze during a call to v.info
with cpu use at 0% and lots of free RAM.
^C did not seem to work from the msys rxvt terminal.. had to "X"
the term window.
now added -x to the shebang in the script (not sure if that does
anything on wingrass), set DEBUG=5, and used --verbose. It's still
running after ~10 minutes, lots and lots of debug messages to get
through...  will try DEBUG=3 or less next time.
Hamish
