[GRASS-user] wx python: multiple selection
Jarek Jasiewicz jarekj at amu.edu.pl
Mon Jul 26 10:38:09 EDT 2010
Daniel Victoria pisze:
> Hi Jarek,
> I might be answering a bit late but here it goes....
> I wxgui you can choose one raster map at a time. If the input is for
> multiple maps it will add the map to the end of the list. So, the idea
> is:
> Click on the drop down menu arrow and choose raster 1
> Click on drop down menu arrow again and choose raster 2
> do this for as many rasters as you wish
> Cheers
> Daniel
Hi Daniel,
I notice that!
It good solution when I need add 2-5 maps, no more
I only ask what about situation when I must add more than 40 maps in
r.to.rast3d? In tcltk version I used CTRL + click to select necessary
maps at once
So it means that such situation command must be created externally and
next passed to terminal.
Jarek
> 2010/7/23 Jarek Jasiewicz <jarekj at amu.edu.pl>:
>> Hi.
>> Sorry for naive question, but in fact I try to use wx since few days, so
>> maybe I lost something...
>> How to made multiple map selection in wx without repetition of choosing map
>> from list
>> (look for something like control+click in tcltk menu gui)
>> when multiple scope of map is needed (for example r.to.rast3d, v.patch)
>> manual method is little frustrating
>> cheers
>> J.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
