[GRASS-user] Re: r.mapcalculator / r.mapcalc not producing raster
LeeDaniel Lee.Daniel.1986 at gmail.com
Fri Feb 18 13:36:30 EST 2011
Wow, it looks like your output raster is really, really small - only 400
cells. Is that correct? It also has values (you can tell by the min/max
values in the metadata). That means that GRASS is producing something. Have
you tried setting the regional settings to match test_combo? If you're
importing into a new location without having set the regional settings
before, it could be that your regional settings don't allow GRASS to display
the map.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-mapcalculator-r-mapcalc-not-producing-raster-tp6041018p6041044.html
Sent from the Grass - Users mailing list archive at Nabble.com.
