[GRASS-user] GRASS Database doesn't copy correctly
Rainer M Krug r.m.krug at gmail.com
Sat Jul 23 07:57:41 EDT 2011
On Sat, Jul 23, 2011 at 12:09 AM, Daniel Lee <lee at isi-solutions.org> wrote:
> I tried compressing it and moving the compressed file to the server, that
> worked.
Great.
> I'd never heard of rsync before - that sounds like an elegant solution,
> I'll try that one.
Absolutely - especially, if you copy the data regularly. But even for a
single copy of a larger amount of data, rsync is quite useful.
Otherwise I at least have the tarball version on the server now.
True - that's always useful.
> Thanks!
Pleasure,
Cheers,
Rainer
> On Thu, Jul 21, 2011 at 12:30 PM, Rainer M Krug <r.m.krug at gmail.com>wrote:
>> On Thu, Jul 21, 2011 at 12:12 PM, <Lee at isi-solutions.org> wrote:
>>> > OS desktop and server? permission issues? Are hidden files copied? is
>>> the server hdd full? File system on desktop and server? If the desktop
>>> allows files >4GB, does the server as well? How did you copy?
>>> > What about archiving on desktop, and extracting archive on server?
>>> > Questions over questions.
>>> Good question questions ;)
>>> OS desktop is OpenSUSE 11.4, permission issues might have been the
>>> problem but I made sure by trying to copy them this time as root (this
>>> computer recognizes the folder as belonging to root, for whatever reason, so
>>> theoretically I would have had issues, although I never do with the other
>>> computers). Hidden files should be copied - I did a drag and drop operation
>>> with the file manager and that should copy hidden files contained in the
>>> copied folders (at least that's the way it works when I test it out on my
>>> desktop, but since the command behind the copying is probably cp it should
>>> work the same when I copy it to a server). Server HDD still has lots of
>>> room, more than a TB. File system is on the desktop is Ext4, I can't find
>>> any documentation on the NAS server but it's a Black Armor from Seagate and
>>> I assume it's NTFS internally. I use CIFS to talk to it. It's definitely got
>>> files on it that are > 4 GB.
>>> Archiving on the desktop and moving the archive to the server is a good
>>> idea, I'll try it out and report back :)
>> Or you could try rsync - usually the best for these kind of things.
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel :       +33 - (0)9 53 10 27 44
>> Cell:       +33 - (0)6 85 62 59 98
>> Fax (F):       +33 - (0)9 58 10 27 44
>> Fax (D):    +49 - (0)3 21 21 25 22 44
>> email:      Rainer at krugs.de
>> Skype:      RMkrug
> B.Sc. Daniel Lee
> Geschäftsführung für Forschung und Entwicklung
> ISIS - International Solar Information Solutions
> Deutschhausstr. 10
> 35037 Marburg
> Festnetz: +49 6421 379 6256
> Mobil: +49 176 6127 7269
> E-Mail: Lee at isi-solutions.org
> Web: http://www.isi-solutions.org
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
South Africa
Skype:      RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110723/6a7057b9/attachment.html
