[GRASS-user] R.proj Problems Creating Table
Dave Kindem dkindem at gmail.com
Sun Jan 1 08:43:50 EST 2012
Hello,
I have created a vector layer from a database table in an XY location (accidents_xy).  Both the topology and a database table (accidents_xy) seem to have been created correctly.  When I try to re-project the layer into a UTM location using r.proj, I receive the following error:
> GRASS 6.4.1 (GRGHM_UTM):~ > v.proj input=accidents_xy location=InterurbanTest output=accidents_utm
> DBMI-SQLite driver error:
> Cannot create table:
> create table sqlite.accidents_utm ( Name text, cat integer, Longitude double precision, Latitude double precision, Type text, Description text )
> unknown database sqlite
> WARNING: Unable to create table <sqlite.accidents_utm>
> WARNING: Unable to copy table <sqlite.accidents_utm>
> WARNING: Failed to copy attribute table to output map
> Building topology for vector map <accidents_utm>...
> Registering primitives...
> 62 primitives registered
> 62 vertices registered
> Building areas...
>  100%
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
>  100%
> Number of nodes: 62
> Number of primitives: 62
> Number of points: 62
> Number of lines: 0
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
The topology layer is created and displays (accidents_utm), but there is no database table.   I am running GRASS 6.4.1 and the Python GUI on a Mac, OS X 10.6.8.
Thanks for any suggestions about how to resolve the issue.
Dave
Dave Kindem
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120101/9af4d5d8/attachment.html
