[GRASS-user] How to create 500m DEM from 90m DEM
sgw00412 at nifty.com sgw00412 at nifty.com
Mon Jan 2 20:37:29 EST 2012
Dear Markus and all
Thank you for your useful advice.
>no, it should be r.resamp.stats:
>http://grass.osgeo.org/wiki/Interpolation#Resampling_of_raster_maps_to_coarse
r_resolution
I visited this site and checked 'finer', 'coarser' and 'sparse'.
My case is 'coarser' (90m -> 500m), so it should be used 'r.resamp.stats', I s
ee.
Thanks
Best,
Yasuo shimada: Japan weather association
----- Original Message -----
>From: Markus Neteler <neteler at osgeo.org>
>Date: Mon, 2 Jan 2012 21:40:37 +0100
>Subject: Re: [GRASS-user] How to create 500m DEM from 90m DEM
>To: sgw00412 at nifty.com
>Cc: GRASS user list <grass-user at lists.osgeo.org>
>2012/1/2  <SGW00412 at nifty.com>:
>> Dear Markus and all
>>> Of course - the vector is just used to find the target area of
>>> the raster map.
>> Yes, I understood it. Thanks.
>> So, at web site grass manual, I found 'r.resamp.interp' command.
>> When I would like to create this under same datum and projection
>> with only difference resolutions, then may I use this command ?
r_resolution
>(r.resamp.interp is used to reach finer resolution, see the same
> Wiki page).
>Markus
