[GRASS-user] Difference in sunset/sunrise time between r.sun and r.sunmask
Stephen Sefick sas0025 at auburn.edu
Mon Jan 2 10:19:18 EST 2012
If you use R there is a sunrise.set function in the StreamMetabolism
package (shameless promotion).  That may be helpful.
Stephen Sefick
On 01/02/2012 06:57 AM, Büro Seling wrote:
> Dear Group!
> Happy New Year @all!
> I work on a Linux GRASS 6.4.2 RC1. The area of interest is in central
> Europe and
> the projection is WGS84(EPSG:4326).
> When I use the r.sun module and let it show the sunset/sunrise time
> and compare
> it with the sunset/sunrise from a map created with r.sunmask I see great
> differences (up to 50 minutes).
> It is not the timezone (which is set correctly) in r.sunmask.
> The results from r.sunmask seem to be, according to other sources,
> seem to be
> right, but the results from r.sun are fare off.
> Please give a suggestions or help!
> Stefan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
