[GRASS-user] Set default cell type to FCELL?
Paulo van Breugel p.vanbreugel at gmail.com
Tue Jan 10 08:10:27 EST 2012
Yes, also check the manual for r.mapcalc (e.g.
http://grass.fbk.eu/gdp/html_grass64/r.mapcalc.html), it is described there
somewhere I think
On Tue, Jan 10, 2012 at 3:23 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 10/01/12 13:17, Paulo van Breugel wrote:
> > When you include in any one of your multiplication a number with
> > at least one decimal your result should be a floating raster.
> > Perhaps not
> so
> oldmap * 1
> results in a raster of the same type as oldmap,
> where
> oldmap * 1.0
> would result in a FCELL?
> > as easy as what you are asking for, but it shouldn't be too error
> > prone, should it?
> In principal not - but I have to check the whole simulation.
> Thanks,
> Rainer
> > Paulo
> > On Tue, Jan 10, 2012 at 3:08 PM, Rainer M Krug <r.m.krug at gmail.com
> > <mailto:r.m.krug at gmail.com>> wrote:
> > On 10/01/12 12:50, Massimiliano Cannata wrote:
> >> Hi, not sure to have understood what you want to do but maybe
> >> using r.mapcalc functions: - double(x)   -->     convert x to
> >> double-precision floating point - float(x)       -->    convert
> >> x to single-precision floating point
> > Sorry for not being more clear.
> > What you suggest is exactly what I am doing - but it is very error
> > prone, as I have to put this into numerous calculations (this is
> > part of a simulation model).
> > What I would like to do is tho change the default type from CELL
> > to FCELL - i.e. whenever a new raster is created, it will *always*
> > and *automatically* be saved in a FCELL raster, even if it only
> > contains integer values, and not in a CELL raster.
> > Cheers,
> > Rainer
> >> Maxi
> >> On 01/10/2012 09:21 AM, Rainer M Krug wrote: -----BEGIN PGP
> >> SIGNED MESSAGE----- Hash: SHA1
> >> Hi
> >> I have huge values in my raster cells and I am manually always
> >> setting thrm to FCELL. Is there a possibility to instruct GRASS
> >> to use FCELL (or DCELL) as a default instead of CELL?
> >> Thanks
> >> Rainer
> >> - -- Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc
> >> (Conservation Biology, UCT), Dipl. Phys. (Germany)
> >> Centre of Excellence for Invasion Biology Stellenbosch
> >> University South Africa
> >> Tel :       +33 - (0)9 53 10 27 44 Cell:       +33 - (0)6 85 62
> >> 59 98 Fax :       +33 - (0)9 58 10 27 44
> >> Fax (D):    +49 - (0)3 21 21 25 22 44
> >> email:      Rainer at krugs.de <mailto:Rainer at krugs.de>
> >> Skype:      RMkrug
> > _______________________________________________ grass-user mailing
> > list grass-user at lists.osgeo.org
> > <mailto:grass-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Stellenbosch University
> South Africa
> Cell:       +33 - (0)6 85 62 59 98
> Skype:      RMkrug
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.11 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk8MLcIACgkQoYgNqgF2egoSMQCePKxF92PrrqiAwqo2OLmlthyf
> NkgAnjfdAf6dx1lz02Rnyu4g5gkPUZi3
> =HmpG
> -----END PGP SIGNATURE-----
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120110/80d1fdc8/attachment-0001.html
