[GRASS-user] Set default cell type to FCELL?
Tue Jan 10 22:49:43 EST 2012
Rainer M Krug wrote:
> What I would like to do is tho change the default type from CELL to
> FCELL - i.e. whenever a new raster is created, it will *always* and
> *automatically* be saved in a FCELL raster, even if it only contains
> integer values, and not in a CELL raster.
This isn't possible. If a module generates a CELL map, it's invariably
because it's performing the calculations using integers. Converting
the final result to floating-point wouldn't help; if the integer
calculations overflow, converting the result to floating-point won't
"undo" the overflow.
Some modules will generate either integer or floating-point output
depending upon the type of the inputs.
> so
> oldmap * 1
> results in a raster of the same type as oldmap,
Arithmetic operations on mixed types promote to the lesser type to the
greater type, where CELL < FCELL < DCELL.
> where
> oldmap * 1.0
> would result in a FCELL?
Actually, it will result in DCELL. r.mapcalc follows C syntax:
floating-point literals are double precision unless suffixed with an
"f", so "oldmap * 1.0f" will result in FCELL (unless oldmap is DCELL).
But float(oldmap) or double(oldmap) do the same thing but avoid the
gratuitous multiply operation.
Also:
1. If you are having issues with overflow, you need to promote values
before calculations, e.g. "float(x) * y". Using "float(x * y)" will
result in x*y overflowing, then the overflowed value will be
converted.
2. Single precision (FCELL) only has a 24-bit mantissa, so integers
greater than 2^24 (16777216) cannot always be represented exactly.
Double precision (DCELL) has a 53-bit mantissa.
