[GRASS-user] Compilation of GRASS 6.4.2 from svn on Ubuntu 10.04
Rebecca Bennett rabennett at ymail.com
Fri Jun 8 07:41:24 PDT 2012
Hello,
Great idea but the reason I need to compile from source is to get a newer version than the 6.4.1 in the repo so it won't work for me this time. :(
Cheers,
Rebecca
>________________________________
> From: nikos ves <vesnikos at gmail.com>
>To: Rebecca Bennett <rabennett at ymail.com>
>Cc: GRASS user List <grass-user at lists.osgeo.org>
>Sent: Friday, 8 June 2012, 15:17
>Subject: Re: [GRASS-user] Compilation of GRASS 6.4.2 from svn on Ubuntu 10.04
>Dear Rebecca,
>Since you're on ubuntu I suggest downloading a pre-compiled binary for
>grass ready for use for your distribution (unless you want grass to be
>able to handle something more exotic):
>sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>sudo apt-get update
>sudo apt-get install grass grass-dev
>Regards,
>Nick Ves
>On Fri, 2012-06-08 at 15:00 +0100, Rebecca Bennett wrote:
>> Thanks for your response.
>> No apparently the configure did not complete without error, as I got
>> checking whether to use Tcl/Tk... yes
>> checking for location of Tcl/Tk includes...
>> checking for tcl.h... no
>> configure: error: *** Unable to locate Tcl includes.
>> So that explains why the make won't run. Here is the configure command
>> I'm trying to use (which probably isn't perfect it was just culled of
>> the instructions site)
>> --with-sqlite --with-cairo --with-freetype --with-cxx
>> --with-geos=usr/bin/geos-config --with-gdal=/usr/bin/gdal-config
>> --with-python=/usr/bin/python-config
>> --with-wxwidgets=/usr/bin/wx-config --enable-largefile
>> --with-proj-share=/usr/share/proj/
>> full output in text file attached.
>> Cheers!
>> Rebecca
>>         ______________________________________________________________
>>         Sent: Friday, 8 June 2012, 14:32
>>         on Ubuntu 10.04
>>         Hey Rebecca,
>>         Does the ./configure prior issuing the make command ends
>>         successfully?
>>         Nick Ves
>>         On Fri, 2012-06-08 at 14:17 +0100, Rebecca Bennett wrote:
>>         > Hello all
>>         > Trying to update my GRASS installation from the svn to 6.4.2
>>         on Ubuntu
>>         > Lynx using these instructions
>>         > http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu
>>         > Having worked through all the dependencies I get as far as
>>         >    make -j2 && sudo make install && sudo ldconfig
>>         > and get the following error
>>         >    make: *** No rule to make target
>>         `include/Make/Platform.make'.
>>         > Stop.
>>         > I'm not very good at this so any ideas most welcome!
>>         > best wishes,
>>         > Rebecca
>>         > _______________________________________________
>>         > grass-user mailing list
>>         > grass-user at lists.osgeo.org
>>         > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120608/a0004841/attachment-0001.html>
