[GRASS-user] How to split a line using points?
Rich Shepard rshepard at appl-ecosys.com
Thu Jun 14 08:51:54 PDT 2012
On Thu, 14 Jun 2012, David Montoya wrote:
> I have points over a line and i need to split the line where the points
> are located. The points aren't at the same distance to each other. Any
> idea how to do that?
David,
   If this is a one-off need the quickest solution might be to display the
line over the points on the wxGUI display, then use the digitize function to
split the line at each point.
Rich
