[GRASS-user] How to split a line using points?
David Montoya jdmonto0 at gmail.com
Thu Jun 14 10:00:47 PDT 2012
Hi Rich,
That procedure is completely impractical for me. The picture was a small
example, I have 37 lines, each one with at least 500 points, that's way I
need to automatize the process
On Thu, Jun 14, 2012 at 10:51 AM, Rich Shepard <rshepard at appl-ecosys.com>wrote:
> On Thu, 14 Jun 2012, David Montoya wrote:
>  I have points over a line and i need to split the line where the points
>> are located. The points aren't at the same distance to each other. Any
>> idea how to do that?
> David,
>  If this is a one-off need the quickest solution might be to display the
> line over the points on the wxGUI display, then use the digitize function
> to
> split the line at each point.
> Rich
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
David Montoya González
Ing. Forestal, Universidad Nacional de Colombia
Laboratorio de Sistemas Complejos, UNAL Medellin
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120614/559a96f2/attachment.html>
