[GRASS-user] How to split a line using points?
Vincent Bain bain at toraval.fr
Thu Jun 14 10:40:02 PDT 2012
A brief suggestion, just ideas to feed your inspiration ;-)
I would try to combine v.edit (tool=break) with a set of short lines
created from your "fromnodes" map : we need to retrieve points
coordinates, hoping they are quite coincident with lines vertices of
your "fromlines" map, and create straight vector lines, each with :
	* from-node=break-node
	* to-node=break-node-translated-a-short-distance.
Here's how I would proceed :
v.out.ascii on fromnodes map. It will create a file looking like this
for each feature :
P  1 1
 594125.63    4921115.58
 1     1
then you can turn it (through a script for the huge number of points you
deal with) into :
L  2 1
 594125.63    4921116.58
 1     1
(in this example the short line is pointing 1 m towards north from the
initial point)
Then put back these lines in a "cuts" line map (v.in.ascii).
Run v.edit to make sure frompoints and lines vertices match :
v.edit map=cuts type=line tool=move move=0,0 thresh=-1,<reasonable snap
distance>,0 where="<a statement selecting all lines>" bgmap=fromlines
snap=node
Finally run again v.edit to break lines at intersections (didn't check
if bgmap applies to break tool, you need to check) :
v.edit map=fromlines type=line tool=break where="<a statement selecting
all lines>" bgmap=cuts
Good luck!
Vincent
