[GRASS-user] Re: Pixels values ​​are changed when the layer is exported to vector (column "value" in attribute tables)
Marcello Benigno benigno.marcello at gmail.com
Thu May 3 16:07:57 EDT 2012
Any solution? I also tried using the r.thin but keep having the same problem
Thanks in advance,
2012/5/2 Marcello Benigno <benigno.marcello at gmail.com>
> Hello All,
> After creating my stream network with the command *r.stream.order*, I
> converted the result to vector, with the command *r.to.vect*, something
> wrong happened... the values ​​that were associated with the pixels appear
> exchanged for some features (e.g., in the raster the pixel value is "1" and
> in the vector appears "2"). I wonder if my procedure is wrong or there
> might be some problem related to my data (SRTM) when even a possible GRASS
> bug.
> The link below shows the two overlying layers (problem.png) and it is
> possible to find some places where the values ​​of the raster layer
> (raster.png) does not correspond to the values ​​of the vector layer
> (vector.png).
> http://ge.tt/4FR2l7H?c
> Could anyone help me?
> Thanks in advance *: )*
> *Marcello Benigno B. de Barros Filho*
> Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
> Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
> Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
> http://profmarcello.blogspot.com
> http://about.me/marcello.benigno
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120503/a81eb5d6/attachment.html
