[GRASS-user] v.buffer database error
Falko Engel falko.engel at web.de
Thu May 10 03:56:42 EDT 2012
Am 09.05.2012 23:32, schrieb Markus Neteler:
> On Wed, May 9, 2012 at 5:29 PM, Falko Engel<falko.engel at web.de>  wrote:
>> Dear list,
>> I had a strange behavior of v.buffer today:
>> v.buffer input=mydata output=mydata_buf bufcolumn=my_buf_col
>> results in an error:
>> "DBMI-Postgres driver error:
>> Cannot select:
>> SELECT cat, my_buf_col FROM mydata"
>> However, if I copy the exact statement of the error message into
>> echo "SELECT cat, my_buf_col FROM mydata" | db.select
>> the result is fine!
> You could set this:
> g.gisenv set=DEBUG=3
> then relaunch the command to see if the more detailed output contains
> relevant pieces (to post here, not all please :-).
> To disable debug output, use
> g.gisenv set=DEBUG=0
> Markus
>> I'm using the following setup:
>> Opensuse 11.3, GRASS GIS 6.4.2
>> My attribute tables are stored in a Postgres DB which is located on a
>> network server.
>> All other DB operations in GRASS are fine.
>> Falko
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Dear Markus,
thanks for that hint! It helped finding the error.
I have to explain in a little more detail:
As I said my attribute tables are stored in a Postgres DB. I used to run
the DB on localhost. But some weeks ago I moved it to a network drive
for backup and accessibility reasons. Since I basically copied the old
DB to the network drive the old DB still exists on localhost. So does
the data set I used in the v.buffer example. Same DB name, same table name.
When I use db.select on this dataset I get the DB connection:
D3/3: db_driver_open_database() driver=pg database definition =
'host=my_server,dbname=my_db'
D3/3: parse_conn : host=my_server,dbname=my_db
D3/3: token 0 : host=my_server
D3/3: token 1 : dbname=my_db
D3/3: host = my_server, port = (null), options = (null), tty = (null),
dbname = my_db, user = (null), password = (null), schema = (null)
When I use v.buffer:
D3/3: db_driver_open_database() driver=pg database definition = 'my_db'
D3/3: parse_conn : my_db
D3/3: host = (null), port = (null), options = (null), tty = (null),
So far the problem is clear. v.buffer seems connect to the old DB on
localhost.
But there is another aspect:
When I create a new dataset (using g.copy) with an a attribute table in
the (correct) DB on the network drive v.buffer recognizes it! This new
table doesn't exists on localhost.
Is there a way to pipe the debugging info to a file?
Falko
