[GRASS-user] Re: Problem with r.stream.order
Marcello Benigno benigno.marcello at gmail.com
Mon May 14 10:59:59 EDT 2012
I tested in both Ubuntu and GRASS 32bits and works fine, so the problem is
only in the 64bits version.
[]'s
2012/5/13 Marcello Benigno <benigno.marcello at gmail.com>
> Hello Guys,
> I'm trying to use r.stream.vector, but when creating the table of
> attributes an error occurs. I am using the sqlite driver. How can I solve
> this?
> GRASS 6.5.svn (Litoral):~ > r.stream.order stream=streams dir=dirs
> strahler=streams_strahler shreve=streams_shreve horton=streams_horton
> hack=streams_hack topo=streams_topo table=tb_order
> Reading maps...
>  100%
> Finding nodes...
> Finding longests streams...
> Calculating Strahler's stream order ...
> Calculating Shreeve's stream magnitude ...
> Calculating Hortons's stream order ...
> Calculating Hack's main streams and topological dimension...
> Writing maps...
>  100%
> streams_strahler Done!
> streams_shreve Done!
> streams_hack Done!
> streams_horton Done!
> streams_topo Done!
> Adding table...
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> no such column: inf
> *ERROR: Cannot inset new row: insert into tb_order values (2, 2, -1, 0 ,0,
> *       0, 1, 1, 1, 1, 1, 30.001727, 30.001727 , 30.001727, 0.000000, inf)
> Thanks in advance,
> *Marcello Benigno B. de Barros Filho*
> Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
> Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
> Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
> http://profmarcello.blogspot.com
> http://about.me/marcello.benigno
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120514/4c7cff81/attachment-0001.html
