[GRASS-user] New GRASS tutorials for ecologists
Gianluca Massei agr.gianluca.massei at gmail.com
Fri Nov 16 13:48:33 PST 2012
I'm trying  to install some  extension in grass 7 (compiled from svn
grass_trunk code in ubuntu 12.10) but I get this message for all my tests:
ERROR: MAPSET PERMANENT - permission denied
make: *** [v.surf.icw.tmp.html] Errore 1
rm v.surf.icw.tmp.html
ERROR: Compilation failed, sorry. Please check above error messages.
I can't understand why the "permission is denied" in MAPSET PERMANENT: I've
set all files and folders with "chmod 777 *" and my
$GRASS_ADDON_BASE=/home/gianluca/.grass7/addons.
I hope anybody can help me
gianluca
2012/11/8 R.S. Bhalla <rsbhalla at gmail.com>
> Thank you Dr.Benigno,
> There is no "additional materials" for restricted users as of now. I do
> however intend to build in quizzes and assignments the results of which
> will only be visible to those with teacher privileges - that's more of a
> privacy issue as some courses will be part of formal lectures.
> Guest access is enabled on the courses and I'll re-check to make sure that
> guests can access all the elements.
> I'll be, very shortly, creating a downloadable copy of the courses (CC
> Share Alike NC) and will host it on the front page for persons interested
> in using parts of the courses/tutorials in their for their own work.
> Regards,
> Ravi
> On Thursday 08 November 2012 06:25 AM, Marcello Benigno wrote:
>> Very good your stuff, congrats!
>> I wonder if there will be some additional material for users with
>> restricted access. It is possible that I may have a login?
>> Regards,
>> *Marcello Benigno B. de Barros Filho*
>> Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
>> Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
>> Doutorando em Tecnologia Ambiental e Recursos Hídricos - UFPE
>> http://profmarcello.blogspot.**com <http://profmarcello.blogspot.com>
>> http://about.me/marcello.**benigno <http://about.me/marcello.benigno>
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
Dott. Gianluca Massei, PhD
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121116/5da1c697/attachment.html>
