[GRASS-user] Single grass window as attached display
SWAPAN GHOSH swap.ghsh at gmail.com
Fri Jan 11 03:14:57 PST 2013
*Dear Rashad,*
* *As per your attachment I have change the entire program. But then grass
will not start.
 Please give me a out line how to deploy this program change.
*Thanks & Regards,*
*Swapan*
On Wed, Jan 9, 2013 at 5:59 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> try this attachment
> On Wed, Jan 9, 2013 at 5:37 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>> *Dear Rashad,*
>> Can you please send me the wxPython folder by making it as wxPython.rar
>> and any other related doc from your local copy.
>> This lay out is my exact requirement. And which version of python you
>> used.
>> I am waiting for kind help.
>> *Thanks & Regards,*
>> *Swapan*
>> On Tue, Jan 8, 2013 at 4:31 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>> you may give a look at DataCatalog[1]. code is very old. I have some
>>> changes in my local copy. But didnt get time to push to addons. The idea is
>>> pretty much same and it can also communicate with ossim using planetSasha.
>>> Unfortunately work is incomplete :(
>>> [1]
>>> http://svn.osgeo.org/grass/grass-addons/grass6/gui/wxpython/wx.data_catalog/
>>> [2]
>>> http://www.geofemengineering.it/GeofemEngineering/Blog/Voci/2009/12/13_Planet_-_Sasha.html
>>> On Tue, Jan 8, 2013 at 4:23 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>>> *Dear Vaclav,*
>>>> Thank you very much for your good advice. I am trying to make it as
>>>> single window.
>>>> I have already see the link you send and found it suitable.
>>>> Actually, I am not Python developer. I am basically c\c++ developer for
>>>> console application. Here GUI is built by wxPython. So I have to learn the
>>>> wxPython.
>>>> Once, the problem is solved surely I share it with you and the
>>>> grass-user list.
>>>> *Thanks & Regards*
>>>> *Swapan*
>>>> On Tue, Jan 8, 2013 at 1:55 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>>>>> Hi,
>>>>> this is more dev than user question since a lot of programming is
>>>>> needed. There are some wxGUI code refactoring efforts (code is
>>>>> published in grass 7, description will be published). One of long term
>>>>> goals of refactoring is to enable creation of one big window with lmgr
>>>>> and display. However, this refactoring is not finished and currently
>>>>> it is very hard to reuse wxGUI components/classes to build another
>>>>> GUI.
>>>>> I thing you have two possibilities:
>>>>> 1) Try to connect lmgr and display anyway. Maybe, it is possible to
>>>>> make it work for some task but the whole thing would be probably very
>>>>> buggy.
>>>>> 2) Build a new GUI from components/classes which are already prepared
>>>>> for reuse. There is a wxIClass (iclass, g.gui.iclass) module which
>>>>> reuses mapwindow (widget where a map i placed) and adds some very
>>>>> simple layer management (however, simple layer manager class is still
>>>>> missing). Depends on what you want, but maybe this is the way you want
>>>>> to go.
>>>>> Since this is a problem which is interesting for more people [1,2],
>>>>> please share your ideas and advances.
>>>>> Vaclav
>>>>> [1] http://grasswiki.osgeo.org/wiki/WxGUI#Layout
>>>>> [2] http://grasswiki.osgeo.org/wiki/GRASS_SoC_Ideas_2009#wxGUI
>>>>> On 8 January 2013 08:35, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>>>>> > Dear all,
>>>>> > Any body can help me for technical solution to change the current
>>>>> window for
>>>>> > grass gis 6.5 to attached display as layer manager and display
>>>>> window in a
>>>>> > single window.
>>>>> > Actually I  want to change this detached window for my own perpose.
>>>>> > Thank & Regards,
>>>>> > Swapan Ghosh
>>>>> > _______________________________________________
>>>>> > grass-user mailing list
>>>>> > grass-user at lists.osgeo.org
>>>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Regards,
>>>    Rashad
> Regards,
>    Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130111/5b7856ba/attachment.html>
