[GRASS-user] Single grass window as attached display
Rashad M mohammedrashadkm at gmail.com
Fri Jan 11 04:13:44 PST 2013
what error you are getting?
On Fri, Jan 11, 2013 at 4:44 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> *Dear Rashad,*
> * *As per your attachment I have change the entire program. But then
> grass will not start.
>  Please give me a out line how to deploy this program change.
> *Thanks & Regards,*
> *Swapan*
> On Wed, Jan 9, 2013 at 5:59 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>> try this attachment
>> On Wed, Jan 9, 2013 at 5:37 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>>> *Dear Rashad,*
>>> Can you please send me the wxPython folder by making it as wxPython.rar
>>> and any other related doc from your local copy.
>>> This lay out is my exact requirement. And which version of python you
>>> used.
>>> I am waiting for kind help.
>>> *Thanks & Regards,*
>>> *Swapan*
>>> On Tue, Jan 8, 2013 at 4:31 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>>> you may give a look at DataCatalog[1]. code is very old. I have some
>>>> changes in my local copy. But didnt get time to push to addons. The idea is
>>>> pretty much same and it can also communicate with ossim using planetSasha.
>>>> Unfortunately work is incomplete :(
>>>> [1]
>>>> http://svn.osgeo.org/grass/grass-addons/grass6/gui/wxpython/wx.data_catalog/
>>>> [2]
>>>> http://www.geofemengineering.it/GeofemEngineering/Blog/Voci/2009/12/13_Planet_-_Sasha.html
>>>> On Tue, Jan 8, 2013 at 4:23 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>>>> *Dear Vaclav,*
>>>>> Thank you very much for your good advice. I am trying to make it as
>>>>> single window.
>>>>> I have already see the link you send and found it suitable.
>>>>> Actually, I am not Python developer. I am basically c\c++ developer
>>>>> for console application. Here GUI is built by wxPython. So I have to learn
>>>>> the wxPython.
>>>>> Once, the problem is solved surely I share it with you and the
>>>>> grass-user list.
>>>>> *Thanks & Regards*
>>>>> *Swapan*
>>>>> On Tue, Jan 8, 2013 at 1:55 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>>>>>> Hi,
>>>>>> this is more dev than user question since a lot of programming is
>>>>>> needed. There are some wxGUI code refactoring efforts (code is
>>>>>> published in grass 7, description will be published). One of long term
>>>>>> goals of refactoring is to enable creation of one big window with lmgr
>>>>>> and display. However, this refactoring is not finished and currently
>>>>>> it is very hard to reuse wxGUI components/classes to build another
>>>>>> GUI.
>>>>>> I thing you have two possibilities:
>>>>>> 1) Try to connect lmgr and display anyway. Maybe, it is possible to
>>>>>> make it work for some task but the whole thing would be probably very
>>>>>> buggy.
>>>>>> 2) Build a new GUI from components/classes which are already prepared
>>>>>> for reuse. There is a wxIClass (iclass, g.gui.iclass) module which
>>>>>> reuses mapwindow (widget where a map i placed) and adds some very
>>>>>> simple layer management (however, simple layer manager class is still
>>>>>> missing). Depends on what you want, but maybe this is the way you want
>>>>>> to go.
>>>>>> Since this is a problem which is interesting for more people [1,2],
>>>>>> please share your ideas and advances.
>>>>>> Vaclav
>>>>>> [1] http://grasswiki.osgeo.org/wiki/WxGUI#Layout
>>>>>> [2] http://grasswiki.osgeo.org/wiki/GRASS_SoC_Ideas_2009#wxGUI
>>>>>> On 8 January 2013 08:35, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>>>>>> > Dear all,
>>>>>> > Any body can help me for technical solution to change the current
>>>>>> window for
>>>>>> > grass gis 6.5 to attached display as layer manager and display
>>>>>> window in a
>>>>>> > single window.
>>>>>> > Actually I  want to change this detached window for my own perpose.
>>>>>> > Thank & Regards,
>>>>>> > Swapan Ghosh
>>>>>> > _______________________________________________
>>>>>> > grass-user mailing list
>>>>>> > grass-user at lists.osgeo.org
>>>>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>>>> Regards,
>>>>    Rashad
>> Regards,
>>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130111/0c0391ea/attachment.html>
