[GRASS-user] r.out.xyz: Output error
Stephen Brearley mail at stephenbrearley.name
Sat Mar 30 11:23:32 PDT 2013
Marcus
See what you mean. No, the breaks are just the way I copied it from the
Command Console, as you can tell from the split of 'PERMA' and 'NENT'.
Should be (approx same as in your book):
r.out.xyz input=elev_ned_30m at PERMANENT >
output=D:\_SDB\GIS_DataBase\Grass\_Demo\Demo_locations\nc_spm_08\PERMANENT\e
lev_ned_30m_xyz2
'output' is not recognized as an internal or external command, operable
program or batch file.
  Stephen
-----Original Message-----
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of
Markus Neteler
Sent: 30 March 2013 18:09
To: Stephen Brearley
Cc: GRASS user list
Subject: Re: [GRASS-user] r.out.xyz: Output error
On Sat, Mar 30, 2013 at 6:41 PM, Stephen Brearley
> NENT\elev_ned_30m_xyz2
> operable program or batch file.
To me it looks as if there is a linebreak before the output parameter. How
do you call r.out.xyz - in a scripts?
> I believe this is a 'basic' feature that is unlikely to have been changed.
Right, the output parameter is the same
http://grass.osgeo.org/grass70/manuals/r.out.xyz.html
Changed parameters are listed here:
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Rastermodulechanges
> Has it not been implemented yet, or should I be sticking with 6.4.2?
Please let us know how you execute above command.
Apparently not from the GUI.
Markus
