[GRASS-user] r.out.xyz: Output error
Helmut Kudrnovsky hellik at web.de
Sat Mar 30 14:15:59 PDT 2013
>>   'output' is not recognized as an internal or external command, operable
>> program or batch file.
>To me it looks as if there is a linebreak before the
>output parameter. How do you call r.out.xyz - in a
>scripts?
tested with
GRASS version: 7.0.svn
GRASS SVN Revision: 55573
Build Date: 2013-02-30
GIS Library Revision: 52468 (2012-07-27)
GDAL/OGR: 1.9.2
PROJ.4: 4.8.0
GEOS: 3.3.6dev
SQLite: 3.7.10
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
g.gisenv set=DEBUG=3
r.out.xyz --verbose input=elevation at PERMANENT output=J:\wd\routxyz\test1.txt
D2/3: filename =
C:\OSGeo4W\apps\grass\grass-7.0.svn\scripts\r.out.xyz.py
D2/3: G_file_name(): path = J:\gisdata/nc_spm_08/g7
path issue?
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-out-xyz-Output-error-tp5043808p5043819.html
Sent from the Grass - Users mailing list archive at Nabble.com.
