[GRASS-user] r.out.xyz: Output error
Helmut Kudrnovsky hellik at web.de
Sat Mar 30 14:32:30 PDT 2013
>r.out.xyz --verbose input=elevation at PERMANENT output=J:\wd\routxyz\test1.txt
>D2/3: filename =
>C:\OSGeo4W\apps\grass\grass-7.0.svn\scripts\r.out.xyz.py
>D2/3: G_file_name(): path = J:\gisdata/nc_spm_08/g7
>  'output' is not recognized as an internal or external command, operable
>program or batch file.
but very interesting...if the separator is given manually instead the
default one, r.out.xyz works:
r.out.xyz input=elevation at PERMANENT output=J:\wd\routxyz\test2.csv
separator=,
(Sat Mar 30 22:26:32 2013) Command finished (3 sec)
r.out.xyz input=elevation at PERMANENT output=J:\wd\routxyz\test3.csv
separator=;
(Sat Mar 30 22:28:00 2013) Command finished (2 sec)
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-out-xyz-Output-error-tp5043808p5043820.html
Sent from the Grass - Users mailing list archive at Nabble.com.
