[GRASS-user] help with testing the location wizard for the upcoming release
Helmut Kudrnovsky
hellik at web.de
Mon May 27 02:21:06 PDT 2013
>since there are so many projections and datums and ways to
>select them, it's pretty hard to test for "working/not working"
>as we usally could do. Please try throwing your local odd-ball
>CRS at it and see what happens. (check all the way through to
>'g.proj -p' and 'g.proj -j' in the final location session. make
>sure it does what you'd expect it to do.
gdalinfo iseldem.tif
Driver: GTiff/GeoTIFF
Files: iseldem.tif
Size is 3117, 2601
Coordinate System is:
PROJCS["Lambert Azimuthal Equal Area",
GEOGCS["grs80",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (4471032.628007249900000,2686202.526832540100000)
Pixel Size = (22.717005998822735,-22.717005998819641)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 4471032.628, 2686202.527) ( 11d58'53.33"E, 47d16'16.87"N)
Lower Left ( 4471032.628, 2627115.594) ( 11d57'41.52"E, 46d44'22.62"N)
Upper Right ( 4541841.536, 2686202.527) ( 12d54'57.39"E, 47d15' 1.05"N)
Lower Right ( 4541841.536, 2627115.594) ( 12d53'11.78"E, 46d43' 7.68"N)
Center ( 4506437.082, 2656659.061) ( 12d26'11.02"E, 46d59'45.72"N)
location wizard => georeferenced file iseldem.tif
g.region -p
projection: 99 (Lambert Azimuthal Equal Area)
zone: 0
datum: etrs89
ellipsoid: grs80
north: 2686202.52683254
south: 2627115.59422961
west: 4471032.62800725
east: 4541841.53570558
nsres: 22.717006
ewres: 22.717006
rows: 2601
cols: 3117
cells: 8107317
g.proj -p
-PROJ_INFO-------------------------------------------------
name : Lambert Azimuthal Equal Area
proj : laea
datum : etrs89
ellps : grs80
lat_0 : 52
lon_0 : 10
x_0 : 4321000
y_0 : 3210000
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
g.proj -j
+proj=laea
+lat_0=52
+lon_0=10
+x_0=4321000
+y_0=3210000
+no_defs
+a=6378137
+rf=298.257222101
+towgs84=0.000,0.000,0.000
+to_meter=1
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/help-with-testing-the-location-wizard-for-the-upcoming-release-tp5055791p5055897.html
Sent from the Grass - Users mailing list archive at Nabble.com.
