[GRASS-user] help with testing the location wizard for the upcoming release
Helmut Kudrnovsky
hellik at web.de
Mon May 27 02:37:35 PDT 2013
>since there are so many projections and datums and ways to
>select them, it's pretty hard to test for "working/not working"
>as we usally could do. Please try throwing your local odd-ball
>CRS at it and see what happens. (check all the way through to
>'g.proj -p' and 'g.proj -j' in the final location session. make
>sure it does what you'd expect it to do.
testgkat28.prj
PROJCS["MGI_Ferro_M28",
GEOGCS["GCS_MGI_Ferro",
DATUM["D_MGI",
SPHEROID["Bessel_1841",6377397.155,299.1528128]],
PRIMEM["Ferro",-17.66666666666667],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",150000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",28.0],
PARAMETER["Scale_Factor",1.0],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
GRASS version: 6.4.3svn
GRASS SVN Revision: 56413
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.9.2
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
Select WKT or PRJ file
g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: hermannskogel
ellipsoid: bessel
north: 1
south: 0
west: 0
east: 1
nsres: 1
ewres: 1
rows: 1
cols: 1
cells: 1
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : tmerc
datum : hermannskogel
ellps : bessel
lat_0 : 0
lon_0 : 28
k : 1
x_0 : 150000
y_0 : 0
pm : ferro
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : Meter
units : Meters
meters : 1
g.proj -j
+proj=tmerc
+lat_0=0
+lon_0=28
+k=1
+x_0=150000
+y_0=0
+pm=ferro
+no_defs
+a=6377397.155
+rf=299.1528128
+towgs84=653.000,-212.000,449.000
+to_meter=1
no asking which transformation should be used.
"Used in whole hermannskogel region: towwgs84=653.000,-212.000,449.000" is
preselected, but not the best e.g. if location used for Austria.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/help-with-testing-the-location-wizard-for-the-upcoming-release-tp5055791p5055901.html
Sent from the Grass - Users mailing list archive at Nabble.com.
