[GRASS-user] Wingrass Raster Layer Manager issue
Bulent Arikan bulent.arikan at gmail.com
Thu Oct 10 01:04:06 PDT 2013
Dear List,
I am having trouble with the Layer Manager in winGRASS 6.4.3.1 downloaded from (http://grass.osgeo.org/grass64/binary/mswindows/native/). This is a PC running Windows 7.
The problem is that when I want to add a raster or vector layer, that separate window that needs to pop up is not coming. Rather, the Layer Manager creates a layer with no name. I tried to use the "rename" option by right clicking. I types the name of the map but it dis not work. I also could not remove the layer.
I downloaded and installed the same application package on a different PC with the same OS and I did not have the issue. This suggests to me that this is an issue about the computer I am using. I have not seen anything like that. Am I missing an additional file? Should I download and install .NET Framework (although, GRASS launches fine).
Thank you,
BÜLENT
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131010/a3267486/attachment.html>
