[GRASS-user] Wingrass Raster Layer Manager issue
Vaclav Petras wenzeslaus at gmail.com
Thu Oct 10 09:45:08 PDT 2013
Hi Bülent,
can you check the Command console tab in the Layer Manager which is the
second item from the left at the bottom of Layer Manager window? There
might be an error message in there. You may also check the (black) windows
command line.
The layer with the label "raster (double click to change properties)" is
created immediately when you press the "Add raster map layer" button. If
there is no text, it is a problem.
This seems that this will be hard to reproduce, so it would be great help
if you double check all consoles, all opened windows, try this with nightly
build of GRASS 7, do some screenshots (1)... it's hard to say what is
important. For now it could be enough if you just check the Command console.
Vaclav
(1) You may want to send the screenshots only to me, to avoid file size
limit check in the mailing list.
On Thu, Oct 10, 2013 at 4:04 AM, Bulent Arikan <bulent.arikan at gmail.com>
wrote:
> Dear List,
> I am having trouble with the Layer Manager in winGRASS 6.4.3.1 downloaded
from (http://grass.osgeo.org/grass64/binary/mswindows/native/). This is a
PC running Windows 7.
> The problem is that when I want to add a raster or vector layer, that
separate window that needs to pop up is not coming. Rather, the Layer
Manager creates a layer with no name. I tried to use the "rename" option by
right clicking. I types the name of the map but it dis not work. I also
could not remove the layer.
> I downloaded and installed the same application package on a different PC
with the same OS and I did not have the issue. This suggests to me that
this is an issue about the computer I am using. I have not seen anything
like that. Am I missing an additional file? Should I download and install
.NET Framework (although, GRASS launches fine).
> Thank you,
> BÜLENT
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131010/0872d22d/attachment.html>
