[GRASS-user] r.li circular window and not integer radius
Sergio Vignali vignalisergio30 at gmail.com
Tue Aug 26 04:49:48 PDT 2014
Ok Markus, I'll check it in GRASS GIS 7 as soon as possible!
There in another problem now, if I try to run r.li.shannon, r.li.simpson or
other r.li module of r.li suite
with a circulare moving window I get the error
"Illegal areas disposition"
I've searched and there is a fixed ticked, #2327, but for Windows OS and
GRASS GIS 7
Sergio
2014-08-23 19:14 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> On Sat, Aug 23, 2014 at 5:36 PM, Sergio Vignali
> <vignalisergio30 at gmail.com> wrote:
> > Define sampling areas
> > -Moving window
> > Use keyboard to define moving window dimension
> > -Circle
> > What radius size (in metres)?
> > Here you can use only an integer radius, if you try with a real number
> the
> > tool shows an alert window: "Type integer values"
> I suppose that the integer test in is wrong as it should exclude the
> metric circular buffer:
> grass64/raster/r.li/r.li.setup/r.li.windows.tcl
> (around line 175)
> Likely worth a bug report in http://trac.osgeo.org/grass/
> If you have time, please check if it works ok in GRASS GIS 7 (which
> can be installed in parallel to GRASS GIS 6).
> Markus
> PS: unrelated - I have added screenshots etc here:
> http://grass.osgeo.org/grass70/manuals/g.gui.rlisetup.html
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140826/818b4c7f/attachment.html>
