[GRASS-user] r.li circular window and not integer radius
Sergio Vignali vignalisergio30 at gmail.com
Sat Aug 30 04:42:11 PDT 2014
Hi Markus,
I've just checked in GRASS 7.
If I use an integer radius or a real number the module doesn't give an
error (see below)
https://www.dropbox.com/s/vv5j0xkzb90j9gv/mv_setting.png?dl=0
but it don't create the configuration file as you can see in the image below
https://www.dropbox.com/s/5akiej27d9nwxec/mv_edit.png?dl=0
and any tools of r.li module doesn't work, see the image below
https://www.dropbox.com/s/kbbm5udk81rwwsn/r_li_shannon.png?dl=0
with a square moving window it works fine
What do you suggest?
2014-08-23 19:14 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> On Sat, Aug 23, 2014 at 5:36 PM, Sergio Vignali
> <vignalisergio30 at gmail.com> wrote:
> > Define sampling areas
> > -Moving window
> > Use keyboard to define moving window dimension
> > -Circle
> > What radius size (in metres)?
> > Here you can use only an integer radius, if you try with a real number
> the
> > tool shows an alert window: "Type integer values"
> I suppose that the integer test in is wrong as it should exclude the
> metric circular buffer:
> grass64/raster/r.li/r.li.setup/r.li.windows.tcl
> (around line 175)
> Likely worth a bug report in http://trac.osgeo.org/grass/
> If you have time, please check if it works ok in GRASS GIS 7 (which
> can be installed in parallel to GRASS GIS 6).
> Markus
> PS: unrelated - I have added screenshots etc here:
> http://grass.osgeo.org/grass70/manuals/g.gui.rlisetup.html
Sergio Vignali
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140830/2495693d/attachment.html>
