[GRASS-user] g.extension -
caumann craigaumann at gmail.com
Thu Jan 30 22:57:40 PST 2014
Here is what I am seeing:
GRASS 7.0.svn (newLocation):~/Desktop > g.version -rge
version=7.0.svn
date=2013
revision=
build_date=2013-12-11
Segmentation fault (core dumped)
It segmentation faults on even this simple command...
On Thu, Jan 30, 2014 at 8:12 PM, wenzeslaus [via OSGeo.org] <
ml-node+s1560n5101073h84 at n6.nabble.com> wrote:
> On Thu, Jan 30, 2014 at 8:15 PM, Craig Aumann <[hidden email]<http://user/SendEmail.jtp?type=node&node=5101073&i=0>
> > wrote:
>> The 64 bit version of grass70-dev is installed, but not the i386 version
>> (see no reason, as the rest of the install is 64 bit).
>> caumann at ubuntu:~$ dpkg --get-selections | grep "grass"
>> grass deinstall
>> grass70-core install
>> grass70-dev install
>> grass70-dev-doc install
>> grass70-doc install
>> grass70-gui install
>> Hi, I cannot say anything about packages, I remember some problems with
> g.version. But anyway, can you please run the following command?
> g.version -rge
> This might tell us what is happening inside of grass.version()['version'].
> split('.').
> Thanks,
> Vaclav
>> On Thu, Jan 30, 2014 at 5:12 PM, Markus Neteler <[hidden email]<http://user/SendEmail.jtp?type=node&node=5101073&i=1>
>> > wrote:
>> On Thu, Jan 30, 2014 at 11:30 PM, caumann <[hidden email]<http://user/SendEmail.jtp?type=node&node=5101073&i=2>>
>>> wrote:
>>> > So I'm trying to install r.geomorphon from within g.extension in Grass
>>> 7.0 on
>>> > Ubuntu 12.04 LTS.  I'm getting an error within g.extension (see below)
>>> about
>>> > not finding the "grass version".   Mine is a binary installation of
>>> Grass
>>> > 7.0.   Am I missing some package?   ???
>>> Probably yes: grass70-devel (don't know the exact package name) - it
>>> is installed?
>>> Markus
>> grass-user mailing list
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5101073&i=3>
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5101073&i=4>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/g-extension-tp5101045p5101073.html
>  To unsubscribe from g.extension -, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5101045&code=Y3JhaWdhdW1hbm5AZ21haWwuY29tfDUxMDEwNDV8MTQzODE1ODA2Nw==>
> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-extension-tp5101045p5101092.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140130/fbd7b906/attachment.html>
