[GRASS-user] g.extension -
Vaclav Petras wenzeslaus at gmail.com
Fri Jan 31 11:18:51 PST 2014
On Fri, Jan 31, 2014 at 1:57 AM, caumann <craigaumann at gmail.com> wrote:
> Here is what I am seeing:
> GRASS 7.0.svn (newLocation):~/Desktop > g.version -rge
> version=7.0.svn
> date=2013
> revision=
> build_date=2013-12-11
> Segmentation fault (core dumped)
> It segmentation faults on even this simple command...
> Yes, it is funny. But it should actually limited just to g.version.
Craig, the workaround is compile GRASS yourself. Maybe, it's time to report
this g.version seg fault as bug. I cannot tell you more now but perhaps
other can.
Does somebody know if this be related to r58417 which was fixed in r58452
and discussed in [GRASS-user] grass70 problem with gui or to [GRASS-dev]
grass70 build error on Ubuntu raring?
http://trac.osgeo.org/grass/changeset/58452
http://trac.osgeo.org/grass/changeset/58417
http://lists.osgeo.org/pipermail//grass-user/2013-October/069088.html
http://lists.osgeo.org/pipermail/grass-dev/2013-June/064529.html
> On Thu, Jan 30, 2014 at 8:12 PM, wenzeslaus [via OSGeo.org] <[hidden
> email] <http://user/SendEmail.jtp?type=node&node=5101092&i=0>> wrote:
>> On Thu, Jan 30, 2014 at 8:15 PM, Craig Aumann <[hidden email]<http://user/SendEmail.jtp?type=node&node=5101073&i=0>
>> > wrote:
>>> The 64 bit version of grass70-dev is installed, but not the i386 version
>>> (see no reason, as the rest of the install is 64 bit).
>>> caumann at ubuntu:~$ dpkg --get-selections | grep "grass"
>>> grass deinstall
>>> grass70-core install
>>> grass70-dev install
>>> grass70-dev-doc install
>>> grass70-doc install
>>> grass70-gui install
>>> Hi, I cannot say anything about packages, I remember some problems with
>> g.version. But anyway, can you please run the following command?
>> g.version -rge
>> This might tell us what is happening inside of
>>  grass.version()['version'].split('.').
>> Thanks,
>> Vaclav
>>> On Thu, Jan 30, 2014 at 5:12 PM, Markus Neteler <[hidden email]<http://user/SendEmail.jtp?type=node&node=5101073&i=1>
>>> > wrote:
>>> On Thu, Jan 30, 2014 at 11:30 PM, caumann <[hidden email]<http://user/SendEmail.jtp?type=node&node=5101073&i=2>>
>>>> wrote:
>>>> > So I'm trying to install r.geomorphon from within g.extension in
>>>> Grass 7.0 on
>>>> > Ubuntu 12.04 LTS.  I'm getting an error within g.extension (see
>>>> below) about
>>>> > not finding the "grass version".   Mine is a binary installation of
>>>> Grass
>>>> > 7.0.   Am I missing some package?   ???
>>>> Probably yes: grass70-devel (don't know the exact package name) - it
>>>> is installed?
>>>> Markus
>>> grass-user mailing list
>>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5101073&i=3>
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> [hidden email] <http://user/SendEmail.jtp?type=node&node=5101073&i=4>
>>  If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/g-extension-tp5101045p5101073.html
>>  To unsubscribe from g.extension -, click here.
>> NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: g.extension -<http://osgeo-org.1560.x6.nabble.com/g-extension-tp5101045p5101092.html>
> Sent from the Grass - Users mailing list archive<http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html>at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140131/91aefe06/attachment.html>
