[GRASS-user] keyError: 'version' g.extension grass7 ubuntu 14.04
Vaclav Petras wenzeslaus at gmail.com
Wed Jun 25 14:37:40 PDT 2014
Carmine, thanks for the message. I'm sending it to the list, it will be
more useful there.
At the end, I actually created a ticket and suggested a patch [1].
If you tried the compilation, let us know if it worked.
Vaclav
[1] http://trac.osgeo.org/grass/ticket/2351
On Wed, Jun 25, 2014 at 12:13 PM, Carmine Massarelli <
carmine.massarelli at ba.irsa.cnr.it> wrote:
> On Wed, Jun 25, 2014 at 11:23 AM, Carmine Massarelli <
>>  Dear all,
>> I have installed Grass 7 on Ubuntu 14.04.
>> I am trying to access to repository
>> http://svn.osgeo.org/grass/grass-addons/grass7/ it but unfortunately i
>> received this error massage that I posted entirely.
>> *Unable to load extensions. Traceback (most recent call last):*
>> *File "/usr/lib/grass70/scripts/g.extension", line 1084, in <module>*
>> *version = grass.version()['version'].split('.')*
>> *KeyError: 'version'*
>>  How did you installed GRASS 7?
> I installed it with grass70-core
>   There is some long term issue in GRASS from repositories and g.version
> command. Try to run there two commands in the terminal:
> g.gisenv set=DEBUG=5
> bash: /usr/lib/grass70/etc/prompt.py: File o directory non esistente
>    g.version -rge
> D2/5: G_file_name(): path =
> /media/massarelli/sdb/Mappe/GRASS/Puglia_Landsat_nord/PERMANENT
> version=7.0.0svn
> date=2014
> revision=
> build_date=2014-06-24
> build_platform=x86_64-pc-linux-gnu
> Errore di segmentazione (core dump creato)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140625/2ad2ac2f/attachment.html>
