[GRASS-user] mantel correlogram
Tyler Smith tyler at plantarum.ca
Tue Mar 11 09:18:20 PDT 2014
Hello,
We're preparing a field sampling program, and would like to determine
a minimum distance between samples to reduce/eliminate spatial
autocorrelation. I think a good approach would be to calculate a
mantel correlogram, and use the range of the correlogram as our
minimum sampling distance.
* Questions
1) is this a reasonable approach
2) if so, how best to do this?
* Details
We have a vector map with the point coordinates of several hundred
potential sampling sites, and ~ 10 raster layers with appropriate data
to test for spatial autocorrelation (WORLDCLIM, soils). I could do
something like the following, but I'm not sure if there's a simpler or
more appropriate approach:
1) extract the raster data for each point
2) save the data to csv; import into R
3) calculate the spatial distances between points, after projecting
the lat-long data into an appropriate scale (?)
4) calculate the climate distance using the WORLDCLIM data
5) use the 'mgram' function in the 'ecodist' package to calculate the
actual correlogram between the spatial distance and climate distance
Any suggestions on the approach or the methods would be welcome!
Thanks,
Tyler
