[GRASS-user] mantel correlogram
Alex Mandel tech_dev at wildintellect.com
Tue Mar 11 09:52:11 PDT 2014
Use R. It includes Moran's I and Geary's C tests for
spatial-autocorrelation. Look like it has  mantel too.
You'll probably need the sp, spdep and rgdal packages. You might also
want to use the Raster package to extract the sampling data, or you can
use spGRASS to tie the R and Grass together.
See chapter 9 (1st ed) of Applied Spatial Data Analysis with R.
http://www.asdar-book.org/
Enjoy,
Alex
On 03/11/2014 09:18 AM, Tyler Smith wrote:
> Hello,
> We're preparing a field sampling program, and would like to determine
> a minimum distance between samples to reduce/eliminate spatial
> autocorrelation. I think a good approach would be to calculate a
> mantel correlogram, and use the range of the correlogram as our
> minimum sampling distance.
> * Questions
> 1) is this a reasonable approach
> 2) if so, how best to do this?
> * Details
> We have a vector map with the point coordinates of several hundred
> potential sampling sites, and ~ 10 raster layers with appropriate data
> to test for spatial autocorrelation (WORLDCLIM, soils). I could do
> something like the following, but I'm not sure if there's a simpler or
> more appropriate approach:
> 1) extract the raster data for each point
> 2) save the data to csv; import into R
> 3) calculate the spatial distances between points, after projecting
> the lat-long data into an appropriate scale (?)
> 4) calculate the climate distance using the WORLDCLIM data
> 5) use the 'mgram' function in the 'ecodist' package to calculate the
> actual correlogram between the spatial distance and climate distance
> Any suggestions on the approach or the methods would be welcome!
> Thanks,
> Tyler
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
