[GRASS-user] r.surf.contour (again)
Mark Seibel mseibel at gmail.com
Thu May 1 06:27:29 PDT 2014
Hi.
> Well I am willing to give it a second try and now I wonder what I can
> do better. Increase resolution? Leave out some contour lines?
To speed up the process to see if the results are desirable, you could
increase the resolution and try the add-on r.surf.nnbathy.   Then decrease
resolution if necessary and applicable.
Mark
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20140501/c191ab07/attachment.html>
