[GRASS-user] Grass7: wxpython exits on display export to file
Vaclav Petras wenzeslaus at gmail.com
Wed Apr 15 08:21:16 PDT 2015
On Wed, Apr 15, 2015 at 10:24 AM, Gustavo Martínez <gmpuljak at yahoo.com.ar>
wrote:
> Hello,
> I'm running GRASS 7.0.0 (2015) (g.version) on Linux Mint 64bits.
> I load a working environment file (.gxw) without problems. I need to
> change one of the vector files of the set and save the display to PNG. When
> I try to save the display after 2 or 3 changes on the vector file and
> exporting to png, the wxpython gui closes without notice.
> I can reload the gui and I get the same behaviour.
> What can I do to diagnose the problem?
Please run
g.gisenv set=WX_DEBUG=5
in the command line before starting GUI using g.gui.
Also, try to exit/close the digitizer before exporting the PNG.
Thanks,
Vaclav
Thanks,
> Gustavo Martínez
> Skype: gmpuljak
> Linkedin: http://ar.linkedin.com/in/gustavomartínezpuljak
> “Que la tierra se vaya haciendo camino ante tus pasos,
> que el viento sople siempre a tus espaldas,
> que el sol brille cálido sobre tu cara,
> que la lluvia caiga suavemente sobre tus campos y,
> hasta tanto volvamos a encontrarnos,
> que Dios te lleve en la palma de su mano.”
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150415/959e5a2d/attachment.html>
