[GRASS-user] Grass7: wxpython exits on display export to file
Gustavo Martínez gmpuljak at yahoo.com.ar
Wed Apr 15 10:45:47 PDT 2015
I've tried to replicate the error with the DEBUG=5 but I couldn't.
However, when I add a north arrow it didn't show and there is an error
message:
GUI D2/5: gcmd.RunCommand(): command started
GUI D3/5: gcmd.RunCommand(): decoding string
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.055268 sec)
GUI D3/5: gcmd.RunCommand(): print error
GUI D3/5: gcmd.RunCommand(): print read error
GUI D3/5: Map.Render() force=True
file=/home/gustavo/Documentos/gis/prueba/zcp/.tmp/neco/5467.0.ppm
GUI D5/5: BufferedWindow.Draw(): id=99, pdctype = image, coord=[0, 0, 0, 0]
GUI D3/5: Map.GetListOfLayers(): numberof=1
GUI D5/5: BufferedWindow.Draw(): id=0, pdctype = image, coord=[706, 60,
64, 240]
GUI D1/5: BufferedWindow.UpdateMap(): render=True, renderVector=True ->
time=0.094455
GUI D4/5: BufferedWindow.OnPaint(): redrawAll=True
GUI D5/5: BufferedWindow.OnLeftDown(): use=pointer
GUI D5/5: BufferedWindow.OnLeftUp(): use=pointer
GUI D5/5: BufferedWindow.OnButtonDClick(): use=pointer
GUI D3/5: Layer.SetCmd(): cmd='d.legend raster=angel_II_2014_capt_r5 en zcp
at=5,50,7,10'
GUI D3/5: Map.AdjustRegion(): {u'rows': 527.0, u'e': -49.0, u'cells':
420546.0, u'cols': 798.0, u'center_northing': -38.0, u'n': -33.0,
u'center_easting': -56.5, u's': -43.0, u'w': -64.0, u'ewres':
0.018796992481203006, u'nsres': 0.018975332068311195}
GUI D3/5: Map.SetRegion(): n-s resol: 0.018975; n-s resol3:
0:00:36.036036; rows: 527; north: -33.0; t-b resol: 1; zone: 0; bottom:
0.000000000000000; rows3: 999; west: -64.0; top: 1.000000000000000;
cols: 798; cols3: 1497; depths: 1; e-w resol: 0.018797; proj: 3; e-w
resol3: 0:00:36.072144; east: -49.0; south: -43.0;
GUI D3/5: Map.GetListOfLayers(): numberof=7
GUI D3/5: Map.GetListOfLayers(): numberof=0
GUI D3/5: Map.Render() type=raster, layer=angel_II_2014_capt_r5 en zcp
GUI D3/5: Map.Render() type=vector, layer=zee_ar en zcp
GUI D3/5: Map.Render() type=vector, layer=zcpau_panaves en zcp
GUI D3/5: Map.Render() type=grid, layer=grid
GUI D3/5: Map.Render() type=vector, layer=america_silueta en zcp
GUI D3/5: Map.Render() type=vector, layer=provincias en zcp
GUI D3/5: Layer.Render(): type=overlay, name=legend
GUI D1/5: gcmd.RunCommand(): d.legend --q
raster=angel_II_2014_capt_r5 en zcp at=5,50,7,10
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.258755 sec)
GUI D3/5: Map.Render() type=overlay, layer=legend
GUI D1/5: gcmd.RunCommand(): g.pnmcomp --o
opacity=1.0,1.0,1.0,1.0,1.0,1.0,1.0 width=798
mask=/tmp/tmpppIQqz.pgm,/tmp/tmpjdJEFN.pgm,/tmp/tmpfJPpb4.pgm,/tmp/tmpOGevlb.pgm,/tmp/tmpKzfZ3_.pgm,/tmp/tmpMiollF.pgm,/tmp/tmpBnzSmp.pgm
height=527 bgcolor=185:231:246
input=/tmp/tmpppIQqz.ppm,/tmp/tmpjdJEFN.ppm,/tmp/tmpfJPpb4.ppm,/tmp/tmpOGevlb.ppm,/tmp/tmpKzfZ3_.ppm,/tmp/tmpMiollF.ppm,/tmp/tmpBnzSmp.ppm
output=/home/gustavo/Documentos/gis/prueba/zcp/.tmp/neco/5467.0.ppm
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.051645 sec)
GUI D3/5: Map.Render() force=False
64, 240]
GUI D1/5: BufferedWindow.UpdateMap(): render=False, renderVector=False
-> time=0.064398
GUI D3/5: BaseToolbar.OnTool(): id = 727
GUI D2/5: Map.ChangeMapSize(): width=798, height=527
GUI D3/5: Layer.Render(): type=raster, name=angel_II_2014_capt_r5 en zcp
GUI D1/5: gcmd.RunCommand(): d.rast --q map=angel_II_2014_capt_r5 en zcp
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.100932 sec)
GUI D3/5: Layer.Render(): type=vector, name=zee_ar en zcp
GUI D1/5: gcmd.RunCommand(): d.vect --q map=zee_ar en zcp fill_color=none
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.121921 sec)
GUI D3/5: Layer.Render(): type=vector, name=zcpau_panaves en zcp
GUI D1/5: gcmd.RunCommand(): d.vect --q map=zcpau_panaves en zcp
fill_color=none
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.112863 sec)
GUI D3/5: Layer.Render(): type=grid, name=grid
GUI D1/5: gcmd.RunCommand(): d.grid --q size=5
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.392034 sec)
GUI D3/5: Layer.Render(): type=vector, name=america_silueta en zcp
GUI D1/5: gcmd.RunCommand(): d.vect --q map=america_silueta en zcp
fill_color=249:239:182
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.238216 sec)
GUI D3/5: Layer.Render(): type=vector, name=provincias en zcp
GUI D1/5: gcmd.RunCommand(): d.vect --q map=provincias en zcp fill_color=none
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.172660 sec)
GUI D1/5: gcmd.RunCommand(): d.grid --q -n size=5
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.099701 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.078321 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.049622 sec)
GUI D5/5: BufferedWindow.Draw(): id=0, pdctype = image, coord=(706, 60)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.095768 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.118657 sec)
fill_color=none
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.110301 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.104040 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.212010 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.163247 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.102368 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.075690 sec)
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.049980 sec)
64, 240]
time=0.109523
GUI D3/5: BaseToolbar.OnTool(): id = 726
GUI D2/5: Map.AddOverlay(): cmd=['d.northarrow', 'at=85.0,25.0'], render=0
GUI D3/5: Layer.__init__(): type=overlay, cmd='d.northarrow
at=85.0,25.0', name=arrow, active=0, opacity=1, hidden=1
GUI D3/5: Layer.SetCmd(): cmd='d.northarrow at=85.0,25.0'
GUI D3/5: Map.GetListOfLayers(): numberof=2
GUI D3/5: Layer.Render(): type=overlay, name=arrow
GUI D1/5: gcmd.RunCommand(): d.northarrow --q at=85.0,25.0
GUI D5/5: DecodeString(): enc=UTF-8
GUI D1/5: gcmd.RunCommand(): get return code 1 (0.286624 sec)
GUI D2/5: gcmd.RunCommand(): error
GRASS_INFO_ERROR(5923,1): [negro]: No existe tal color.
GRASS_INFO_END(5923,1)
Command 'd.northarrow at=85.0,25.0' failed
Details: [negro]: No existe tal color.
GUI D1/5: gcmd.RunCommand(): get return code 0 (0.053295 sec)
64, 240]
-> time=0.052179
> On Wed, Apr 15, 2015 at 10:24 AM, Gustavo Martínez
> <gmpuljak en yahoo.com.ar <mailto:gmpuljak en yahoo.com.ar>> wrote:
>     Hello,
>     I'm running GRASS 7.0.0 (2015) (g.version) on Linux Mint 64bits.
>     I load a working environment file (.gxw) without problems. I need
>     to change one of the vector files of the set and save the display
>     to PNG. When I try to save the display after 2 or 3 changes on the
>     vector file and exporting to png, the wxpython gui closes without
>     notice.
>     I can reload the gui and I get the same behaviour.
>     What can I do to diagnose the problem?
> Please run
> g.gisenv set=WX_DEBUG=5
> in the command line before starting GUI using g.gui.
> Also, try to exit/close the digitizer before exporting the PNG.
> Thanks,
> Vaclav
>     Thanks,
>     _______________________________________________
>     grass-user mailing list
>     grass-user en lists.osgeo.org <mailto:grass-user en lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/grass-user
Gustavo Martínez
Skype: gmpuljak
Linkedin: http://ar.linkedin.com/in/gustavomartínezpuljak
“Que la tierra se vaya haciendo camino ante tus pasos,
que el viento sople siempre a tus espaldas,
que el sol brille cálido sobre tu cara,
que la lluvia caiga suavemente sobre tus campos y,
hasta tanto volvamos a encontrarnos,
que Dios te lleve en la palma de su mano.”
------------ pr�xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150415/432781c1/attachment-0001.html>
