[GRASS-user] Is the location's VAR file required?
G. Allegri giohappy at gmail.com
Wed Feb 18 15:02:58 PST 2015
Everything is working fine now.
The problem with the effective import was the -i option, which I obtained
from another script and I wasn't aware of it...
2015-02-18 23:30 GMT+01:00 G. Allegri <giohappy at gmail.com>:
> I confirm that trunks doesn't causes segfault. Same mapset and location.
> Now I have to figure our why the import doesn't happen:
> v.in.ogr input=/mnt/data/centroids.shp location=workLocation
> output=centroids -ie
> The location is created but is empty.
> Thr same shape is correctly imported from GUI.
> I will double check and try it again...
> Il 18/feb/2015 22:34 "Markus Metz" <markus.metz.giswork at gmail.com> ha
> scritto:
> On Wed, Feb 18, 2015 at 10:14 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>> > On Wed, Feb 18, 2015 at 4:01 PM, Markus Metz <
>> > wrote:
>> >> On Wed, Feb 18, 2015 at 9:25 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> >> wrote:
>> >> > I think we should really implement #2579 [1] in one way or the other.
>> >> > This
>> >> > would make custom setups [2] not necessary for most cases. What do
>> you
>> >> > think? What should be the command line parameters?
>> >> Importing a shapefile to a new location without a VAR file works for
>> >> me, and I think we should find out why it does not work for Giovanni.
>> >> His approach should (must) work as it is.
>> > Could this be related?
>> > http://lists.osgeo.org/pipermail/grass-dev/2014-September/070639.html
>> I think not because I started GRASS in a new location, VAR was
>> created, then I deleted it, then I ran v.in.ogr successfully, and VAR
>> was recreated again. v.in.ogr works for me without a VAR file present.
>> Markus M
>> > Anna
>> >> Markus M
>> >> > Vaclav
>> >> > [1] http://trac.osgeo.org/grass/ticket/2579
>> >> > [2]
>> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
>> >> > On Wed, Feb 18, 2015 at 1:26 PM, G. Allegri <giohappy at gmail.com>
>> wrote:
>> >> >> Hi Markus,
>> >> >> I wrote the details in another recent email and I forgot to write
>> the
>> >> >> here, sorry.
>> >> >> GRASS 7.0.0 RC1 on Ubuntu 14.04.
>> >> >> I'm creating a temporary database with an empty start location,
>> with no
>> >> >> CRS defined (proj code 0, i.e. XY).
>> >> >> My location contains only the the WIND and DEFAULT_WIND files with
>> the
>> >> >> following content:
>> >> >> proj:       0
>> >> >> zone:       0
>> >> >> north:      1
>> >> >> south:      0
>> >> >> east:       1
>> >> >> west:       0
>> >> >> cols:       1
>> >> >> rows:       1
>> >> >> e-w resol:  1
>> >> >> n-s resol:  1
>> >> >> top:        1
>> >> >> bottom:     0
>> >> >> cols3:      1
>> >> >> rows3:      1
>> >> >> depths:     1
>> >> >> e-w resol3: 1
>> >> >> n-s resol3: 1
>> >> >> t-b resol:  1
>> >> >> The env variables I'm using are:
>> >> >> export PYTHONPATH='/usr/lib/grass70/etc/python'
>> >> >> export GISRC='/tmp/tmp9YVf_N/gisrc'
>> >> >> export GRASS_VERSION='7.0.0'
>> >> >> export
>> PATH='/usr/lib/grass70/bin:/usr/lib/grass70/scripts:/home/giova/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin'
>> >> >> export GIS_LOCK=$
>> >> >> export LD_LIBRARY_PATH='/usr/lib/grass70/lib'
>> >> >> export GISBASE='/usr/lib/grass70'
>> >> >> Whatevere shapefile I try to import I obtain a segfault.
>> >> >> This is the test command:
>> >> >> :/ v.in.ogr dsn="/mnt/data/centroids.shp" output=centroids
>> >> >> location=workLocation -ie
>> >> >> If I add the VAR file with:
>> >> >> DB_DRIVER: sqlite
>> >> >> DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
>> >> >> eveythign works fine.
>> >> >> giovanni
>> >> >> 2015-02-18 18:08 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
>> >> >>> On Wed, Feb 18, 2015 at 3:24 PM, G. Allegri <giohappy at gmail.com>
>> >> >>> wrote:
>> >> >>> > I'm getting segmentation faults in case I run a command on a
>> >> >>> > location
>> >> >>> > missing the VAR file.
>> >> >>> On which OS, which GRASS version?
>> >> >>> > I thought it was optional, as it's said here:
>> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#GRASS_databases
>> >> >>> Please post a reproducible example, thanks.
>> >> >>> Markus
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > grass-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150219/b99883d8/attachment-0001.html>
