[GRASS-user] r.massmov
DEBERNARDI DANILO d.debernardi4 at studenti.uninsubria.it
Wed Jan 28 06:42:41 PST 2015
I think that the quickest solution for this problem could be to change my pc platform or use a virtual platform (virtual box)
Could it be ?
What platform does support the r.massmov addon without error or interface problem?
Thanks, for the patience
________________________________________
Da: grass-user-bounces at lists.osgeo.org <grass-user-bounces at lists.osgeo.org> per conto di Helmut Kudrnovsky <hellik at web.de>
Inviato: sabato 24 gennaio 2015 15.17
A: grass-user at lists.osgeo.org
Oggetto: Re: [GRASS-user] r.massmov
> It means that there's something to fix in the module?  Or is a grass issue?
tested here again:
GRASS Version: 7.1.svn
GRASS SVN revision: 64291
Build date: 2015-01-24
Build platform: i686-pc-mingw32
GDAL: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
as r.massmov doesn't show any (re)action, it's hard to say; but I assume a
fix in r.massmov is needed.
a quick test with different debug levels:
g.gisenv set=DEBUG=3
g.gisenv set=DEBUG=5
C:\>r.massmov
C:\>
C:\>r.massmov --help
C:\>
C:\>r.massmov --ui
C:\>
if you try to invoke the module, unfortunately nothing happens: no error
message, no debug message, ...
maybe something with parallelization in windows?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-massmov-tp5181466p5183520.html
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
